주요 콘텐츠로 건너뛰기
Huawei Mate 20 Pro Teardown
17 단계 번역중
17 단계
Huawei Mate 20 Pro Teardown, Final Thoughts: 0 단계, 이미지 1개 중 1개
Final Thoughts
  • The Huawei Mate 20 Pro earns a 4 out of 10 on our repairability scale (10 is the easiest to repair):
  • Many components are modular and can be replaced independently.
  • Battery replacement requires removing only the back panel and midframe.
  • Only standard Phillips screws are used along with an average amount of adhesive.
  • Because of the sandwich build around the motherboard, there are more flex connectors than average and repairs will consume more time.
  • Glued-down front and back glass means greater risk of breakage while making repairs difficult to start.
  • Screen repairs require a lot of disassembly while battling tough adhesive.
  • A broken screen probably means you need to replace the fingerprint reader as well, or vice versa.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
