주요 콘텐츠로 건너뛰기
도움말
4단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
To remove the circuit boards you can remove the 4 short screws as shown.
For the top board you can pry around the edges (use plastic or wood tool). Note that there is a connector on the back that connects to a board inside the compartment on the other side.
The bottom board I recall was just loose. Beware of ruining the other ribbon connector (yellow) attached to it.
For the top board there is a speaker wire (yellow) going behind it that will keep this from being removed. It is thin so it could be broken easily.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
