주요 콘텐츠로 건너뛰기
도움말
5단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Pry lightly around the edge of the main board between the board and the casing to help free the board. Fingernails, a spudger, or plastic opening tools can be used for this task.
DO NOT TRY TO REMOVE THE MAIN BOARD COMPLETELY!!! There are soldered items that need to be dealt with. Follow along closely.
Gently, and I mean gently, pull up on the LED assembly to loosen the main board from the rear casing.
Any resistance should indicate that the board needs to be loosened from the casing, around the edges, more before proceeding.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
