주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
7단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Now you will remove all other connectors from the outer parts of the mainboard. as marked in the Red Rectangles. Gently, pull them out of their connection place.
There is one connector from the mainboard to the little blue board in the bottom righthand corner that is connected on the underside of the mainboard. Just disconnect this one from at the blue board.
You will find that the two connectors labeled in a yellow rectangle are not connected to anything leading me to believe that this mainboard may be used with other model projectors as well.
Remove the five screws marked in the red Circles from the mainboard.
In the Third image you will find the LCD Ribbon Cable on the Center of the Board. You will remove the three of the cables by gently pulling up on either side of the tiny brown connectors attching them to the board
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
