주요 콘텐츠로 건너뛰기
Huawei Mate 30 Pro Teardown
15 단계 번역중
15 단계
Huawei Mate 30 Pro Teardown, Final Thoughts: 0 단계, 이미지 1개 중 1개
Final Thoughts
  • The Huawei Mate30 Pro earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
  • Almost every component is modular and can be replaced independently.
  • Only standard Phillips screws are used.
  • Pull tabs make fairly quick work of battery replacement, once you've carved through the rear cover, plastic frame, and some cables.
  • A few components require extended disassembly for service.
  • The display can be removed without removing the battery, although it's still tough to pry off and impeded by some cables.
  • Glued-down front and back glass means greater risk of breakage, while making all repairs more difficult and lengthy.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
