주요 콘텐츠로 건너뛰기
GPD Win Max v3 Teardown
6 단계
GPD Win Max v3 Teardown: 0 단계, 이미지 1개 중 1개
  • The joystick module do not naturally block removal of motherboard, but the ribbon cable can make movement difficult and dangerous. Remove them if you haven't.
  • Now the motherboard will be available for removal.
  • The triggers are connected by spring contact, but they are trapped under the board.
  • So far, every single screw are Philips PH0. It's good, but it's also bad, since Philips screws can't take as much torque compared to Torx.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
