주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
5단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Repeat the same process on the other panel.
This side is a bit less interesting. You can see which holds up the main circuit board. You can also see the really large Sprague capacitors (45000uF 45V) likely used as a filter for the rectifier.
Interestingly, these large capacitors are screw terminal caps and are screwed directly to the board. Next to these screws you can see the large non-inductive wire wound resistors.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
