3
4
5
6
7
8
To access the front panel, remove these three screws on each side with a #2 philips head screwdriver
You can then pull the frame wide on each side so that the bottom panel comes off.
You see the main power switch, the Bourns 10-turn 1K pot which controls the current set point, the smaller Bourns pot which sets the overvoltage crowbar.
More interesting is the board underneath/behind the voltage selector. This board is populated with lots of ultra high precision resistors, including 0.01% tolerance, 0.025% tolerance and 0.1% tolerance resistors. All are either 1ppm or 2ppm temp coeff. These are ultra high precision even by todays standards.
« 이전
다음 »
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
다음 줄
이전 줄
아래에 새로운 줄 삽입
위에 새로운 줄 삽입
현재 줄 들여쓰기
현재 줄 내어쓰기
현재 줄 삭제
다음 단계로 이동.
이전 단계로 이동.
도움말 열기
