주요 콘텐츠로 건너뛰기
Power Mac G4 Quicksilver Teardown
12 단계
Power Mac G4 Quicksilver Teardown, Power Supply & Fan: 0 단계, 이미지 3개 중 1개 Power Mac G4 Quicksilver Teardown, Power Supply & Fan: 0 단계, 이미지 3개 중 2개 Power Mac G4 Quicksilver Teardown, Power Supply & Fan: 0 단계, 이미지 3개 중 3개
Power Supply & Fan
  • This computer uses a non-standard 22-Pin Apple power supply, plus a 4-Pin 12V connector commonly found in some power supplies.
  • Start by disconnecting the power connectors from the motherboard, and routeing them up to the level of the power supply.
  • Also remove the fan connector, and route that up as well.
  • Remove this Screw as well.
  • Disconnect the Fan Connector.
  • Always be weary of power suppplies, they can be harmful if handled wrong.
  • Fan removal is only three screws. The one circled in yellow, one on the upper left of the frame cage (not shown), and one on the middle bottom of the frame (not shown).
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
