주요 콘텐츠로 건너뛰기
Nexus 5 Teardown
15 단계 번역중
15 단계
Nexus 5 Teardown: 0 단계, 이미지 2개 중 1개 Nexus 5 Teardown: 0 단계, 이미지 2개 중 2개
  • Nexus 5 Repairability Score: 8 out of 10 (10 is easiest to repair).
  • Very modular design allows independent replacement of several wear-prone components—like the headphone jack and speakers.
  • Only very mild adhesive holds the battery in place, making it fairly easy to safely remove and replace.
  • Standardized screws (ten identical #00 Phillips) simplify repairs and reassembly.
  • The back cover is held in place with plastic clips. Sturdy and rather difficult to remove, but easier than glue.
  • The glass and LCD are fused to the display frame. Fixing broken glass will be either expensive or very difficult.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
