주요 콘텐츠로 건너뛰기
PlayStation 4 Teardown
26 단계 번역중
26 단계
PlayStation 4 Teardown, Final Thoughts: 0 단계, 이미지 1개 중 1개
Final Thoughts
  • Sony PlayStation 4 Repairability Score: 8 out of 10 (10 is easiest to repair):
  • No adhesive makes disassembly and reassembly easy.
  • The non-proprietary hard drive is easy to access and replace, and replacing it will not void your warranty.
  • Security screws and tamper-evident seals discourage users from disassembling and repairing their PS4.
  • You'll need to disassemble quite a bit of the device to access the fan for cleaning, and even more for replacement.
  • The sharp mid-plane could cause some damage to your fingers if you're not careful during disassembly.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
