주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
8단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
We should now have removed the 2 big flex cables attached to their respective mutual boards, the 2 antenna wires and the main logic board.
We can now start the process of removing the battery. Using a flat plastic pry tool, pry up the edges of the battery and work your way to the middle from all sides.
Be careful to not bend the battery too much. Another method is using two long thin, flat plastic pry tools to "cut" the adhesive, and pry between the battery and body of the phone starting at the USB end. Do not risk a lithium fire by poking a hole in the battery!
When reassembling, you could use a counter top or something flat to flatten the battery back out.
The third pic is what we should have after the battery is removed.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
