주요 콘텐츠로 건너뛰기
도움말
2단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Two screws hold the power connector in place. Remove these before trying to remove anything else.
Four screws and one cable will remove the speaker assembly.
Three screws and a pop on connector secure the micro-SD reader.
There are several screws that hold the battery tray in place. The battery is held in with fairly strong adhesive, so I didn't try to take it out of the tray.
Three cables are attached to the touch board. I didn't try to remove this board from the frame.
Disconnect the four cable connectors that lay across the battery. The cables with blue tabs do not have a locking mechanism holding the cable in place.
There are two magnets located at the bottom center. More than likely used for a case cover or for a feature not included on this tablet.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
