주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
3단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
The 1000mAh 11.1V lithium polymer battery is attached via a connector, making it delightfully easy to remove.
The second connector is a balance charge connector, which ensures that each of the three battery cells is charging equally, thus optimizing capacity and prolonging battery life.
The battery contains a protection circuit module, which prevents it from discharging too rapidly, over charging, or short circuiting.
Parrot claims the battery will only last about 12 minutes after a full charge, which takes around 90 minutes. Taking your AR.Drone out to the park with only one battery won't get you much play time, unfortunately.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
