주요 콘텐츠로 건너뛰기
도움말
3단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Now on to the formatter.
Remove 2 screws on the I/O port cover.
Remove 6 screws on the formatter cover.
Disconnect 3 connectors to the laser assembly, the cartridge connector, and the control panel.
Disconnect 2 flat flexible cables to the laser assembly and the control board.
While the service manual says not to use a PoziDriv screwdriver, I found that using a normal Phillips screwdriver on the screws in this printer would require excess force and damage the screws, but a PoziDriv screwdriver removed the screws without causing any damage.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
