주요 콘텐츠로 건너뛰기
Apple Wireless Keyboard (A1255) Teardown
17 단계 번역중
17 단계
Apple Wireless Keyboard (A1255) Teardown, Close-up of the compartments: 0 단계, 이미지 3개 중 1개 Apple Wireless Keyboard (A1255) Teardown, Close-up of the compartments: 0 단계, 이미지 3개 중 2개 Apple Wireless Keyboard (A1255) Teardown, Close-up of the compartments: 0 단계, 이미지 3개 중 3개
  • Here you can see the pole that the screw went in. You can remove this, which allows you to remove the power button and the white housing.
  • Also, here is the battery terminal (spring loaded) which had to be forced out. It's held in the tube by the expansion ring, which unfortunately is the best-made bit of this keyboard. I forced it out using a long screw driver, but unfortunately broke the wires. Keyboard had died anyway, thanks Apple.
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
