주요 콘텐츠로 건너뛰기
Microwave Teardown
4 단계
Microwave Teardown, Remove screws from bottom of microwave: 0 단계, 이미지 1개 중 1개
  • On the bottom of the microwave you'll find 9 more phillips screws. Remove the four on the top and bottom of the casing, and four more on the right side which are holding the transformer to the inside of the case. Leave the last screw, which is located in the raised rectangle in the middle of the bottom panel,
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
