주요 콘텐츠로 건너뛰기
Nokia 1208 Mobile Phone Teardown
4 단계
Nokia 1208 Mobile Phone Teardown, Removing each screw: 0 단계, 이미지 3개 중 1개 Nokia 1208 Mobile Phone Teardown, Removing each screw: 0 단계, 이미지 3개 중 2개 Nokia 1208 Mobile Phone Teardown, Removing each screw: 0 단계, 이미지 3개 중 3개
Removing each screw
  • Now take you're screwdriver, and remove those 6 screws you did see in the previous step.
  • Be carefull when you remove the last screw, hold the display assembly in the unit with a finger.
  • Now you can take out the entire display assembly that is attached to the main board.
  • I take you through the display assembly in the next step, because in the shell that houses the entire display assembly, you see a piece with 2 golden feet on it.
  • That is the microphone, and can be replaced with any microphone of the same type
  • Lets go to the next step
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
