주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
15단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Samsung Galaxy Nexus Repairability Score: 6 out of 10 (10 is easiest to repair).
Battery replacement is incredibly simple thanks to the removable rear panel.
Minimal adhesive makes removal of the motherboard and other components a snap.
Headphone jack and speaker assembly are not soldered to the motherboard, so replacement is easy.
The only soldered components are the volume switch and vibrator motor.
Removing the rear case to access the motherboard and other internals requires a lot of careful prying and guitar-picking.
The glass is fused to both the display and the display frame. So don't crack the glass unless you're good with a heat gun, or you're fond of replacing the glass, display, and frame together ($$$).
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
