메인 콘텐츠로 스킵하기
도움말
3단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Insert wisdom here.
Only pry at the front end of the keyboard, as there are easily damaged ribbon cables at the rear of the keyboard.
Using a heat gun on low setting can be used carefully to heat the rear cover and soften the adhesive. Work in sections heating and then gradually prying the sections apart.
Avoid using too much heat otherwise you will distort or melt the cover or other plastic parts. Do not use excessive force to remove the cover as the alloy is thin and bends easily. The keyboard will be permanently distorted.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
