주요 콘텐츠로 건너뛰기
Huawei Mate 9 Teardown
17 단계 번역중
17 단계
Huawei Mate 9 Teardown, Final Thoughts: 0 단계, 이미지 1개 중 1개
Final Thoughts
  • The Huawei Mate 9 earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
  • Most of the components—like both camera units, the loudspeaker, and the USB board—can be replaced. Even the proximity sensor and the NFC antenna are modular.
  • Despite the annoying hexalobe screws, the Mate 9 comes with only a few standard Phillips screws on the inside.
  • The battery is trapped behind some flex cables and is glued tightly into place, but still can be swapped out when its power starts to fade away.
  • Although we are happy to find a headphone jack, it is soldered to the board and calls for special soldering skills if it should fail.
  • Replacing a broken display, one of the most common repairs, will be one of the most difficult ones on this phablet.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
