주요 콘텐츠로 건너뛰기
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
해당 분해도는 수리 안내서가 아닙니다. iMac G3 Model M4984 수리는 저희 서비스 설명서를 사용하십시오.
  1. iMac G3 Model M4984 Teardown, iMac G3 Model M4984 Teardown: 1 단계, 이미지 1/1
    • Here it is - the original iMac, aka the iMac G3
  2. iMac G3 Model M4984 Teardown: 2 단계, 이미지 1/3 iMac G3 Model M4984 Teardown: 2 단계, 이미지 2/3 iMac G3 Model M4984 Teardown: 2 단계, 이미지 3/3
    • Place the iMac upside-down so you can easily access the bottom cover.
    • There is one screw holding the the bottom cover in. Remove it, and then pull on the handle to remove the entire bottom cover.
    • Locate the video cable, motherboard power cable, and auxiliary power cable.
    • Unscrew the video cable and remove it, and remove the other two cables.
  3. iMac G3 Model M4984 Teardown: 3 단계, 이미지 1/3 iMac G3 Model M4984 Teardown: 3 단계, 이미지 2/3 iMac G3 Model M4984 Teardown: 3 단계, 이미지 3/3
    • Slide out the logic board tray, and remove it from the system.
    • All of the contents of the logic board tray can now be removed.
    • The CD drive can be slid out of its slot, and the hard drive is underneath.
    • The logic board can be removed by removing several screws holding it in.
    • The logic board is connected to a power adapter underneath, be sure to carefully detach it as you are removing the logic board.
  4. iMac G3 Model M4984 Teardown: 4 단계, 이미지 1/2 iMac G3 Model M4984 Teardown: 4 단계, 이미지 2/2
    • The bottom plastic cover can be unscrewed and unsnapped. This will require some force, so be careful not to break any of the plastic.
    • Remove the speaker cover by carefully unsnapping it.
    • Remove the plastic bezel by unsnapping it.
    • The top cover (in this case, pink) is held in by two screws at the top of the computer. They are hidden under plastic covers, and must be removed before you can unsnap the top cover.
    • WARNING: Have caution while handling the now-exposed CRT. Some people wish to discharge it before continuing, however if it hasn't been used in a while I would suggest leaving it alone and just not touching it. I am not responsible for any injury or damage resulting from mishandling the CRT!
    • The CRT can be unscrewed and removed from its metal housing.
    • The exposed components can be dangerous to handle, so do this at your own risk.
RJ Kucia
회원 가입일: 11/03/12
349 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 7,339
