주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. iMac G3 Model M4984 Teardown, Logic Board: 1 단계, 이미지 1/1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Teardown: 2 단계, 이미지 1/1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Teardown: 3 단계, 이미지 1/3 iMac G3 Model M4984 Teardown: 3 단계, 이미지 2/3 iMac G3 Model M4984 Teardown: 3 단계, 이미지 3/3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Teardown: 4 단계, 이미지 1/3 iMac G3 Model M4984 Teardown: 4 단계, 이미지 2/3 iMac G3 Model M4984 Teardown: 4 단계, 이미지 3/3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Teardown: 5 단계, 이미지 1/3 iMac G3 Model M4984 Teardown: 5 단계, 이미지 2/3 iMac G3 Model M4984 Teardown: 5 단계, 이미지 3/3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Teardown: 6 단계, 이미지 1/2 iMac G3 Model M4984 Teardown: 6 단계, 이미지 2/2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Teardown: 7 단계, 이미지 1/3 iMac G3 Model M4984 Teardown: 7 단계, 이미지 2/3 iMac G3 Model M4984 Teardown: 7 단계, 이미지 3/3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Teardown: 8 단계, 이미지 1/1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Teardown, Bottom Cover: 9 단계, 이미지 1/1
    • To remove the bottom cover, remove these phillips screws, and pull the bottom cover off the iMac. (Start with the very back and use a flat head screwdriver to pop the main clip. The rest will come off relatively easily.)
  10. iMac G3 Model M4984 Teardown: 10 단계, 이미지 1/3 iMac G3 Model M4984 Teardown: 10 단계, 이미지 2/3 iMac G3 Model M4984 Teardown: 10 단계, 이미지 3/3
    • Removing the faceplate:
    • Remove these phillips screws.
    • Now, pivot the faceplate up about 60 degrees and pull it away from the imac, with some wiggleing, it should come free
Chris Green
회원 가입일: 10/11/09
35,960 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
314 회원들
안내서 1,320개 작성하였습니다
댓글 한 개
yo what happened to this lmao
Tristan Haugh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 45
전체 시간: 8,865
