주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. iPhone dock Teardown, Getting started: 1 단계, 이미지 1/2 iPhone dock Teardown, Getting started: 1 단계, 이미지 2/2
    • Start by flipping the dock upside down.
  2. iPhone dock Teardown, Removing the back: 2 단계, 이미지 1/2 iPhone dock Teardown, Removing the back: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Jimmy
    $7.95
    구매
    • Take your Jimmy and push it in between the bottom cover and the body. Push down to lift the bottom cover.
  3. iPhone dock Teardown, Getting the back off: 3 단계, 이미지 1/2 iPhone dock Teardown, Getting the back off: 3 단계, 이미지 2/2
    • Carefully remove the clips on the side by pushing up with the Jimmy. If needed, use the plastic Opening Picks to keep the back piece from popping back into place.
  4. iPhone dock Teardown, Looking at the dock: 4 단계, 이미지 1/1
    • Remove the dock completely from the plastic frame.
  5. iPhone dock Teardown, Peeling back the black sticker: 5 단계, 이미지 1/3 iPhone dock Teardown, Peeling back the black sticker: 5 단계, 이미지 2/3 iPhone dock Teardown, Peeling back the black sticker: 5 단계, 이미지 3/3
    • The silver adhesive is covering two Phillips screws at opposite ends of the dock. Peel back the adhesive on these areas and remove both screws.
  6. iPhone dock Teardown, Removing fore Phillips 000 screws: 6 단계, 이미지 1/1
    • Remove the back plate once the screws are out.
    • Remove four Phillips #000 screws surrounding the lighting connection.
  7. iPhone dock Teardown, Removing the lighting adapter: 7 단계, 이미지 1/2 iPhone dock Teardown, Removing the lighting adapter: 7 단계, 이미지 2/2
    • A similar adhesive can be found covering the plug for the lightning adaptor. Peel the adhesive back and gently lift the cable to disconnect the adaptor.
Nathan
회원 가입일: 09/21/17
386 평판
안내서 2개 작성하였습니다
댓글 한 개
is it possible to find the lighting connector, since I have one that fell and it got all twisted and damaged and it tore the connector
Uriel Ramos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 2,088
