주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
해당 분해도에 사용된 도구
소개
This break down will enable you to dismantle your ipod nano 1st generation without breaking it.
해당 분해도는 수리 안내서가 아닙니다. iPod Nano 1st Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. 1.    Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool into the connection point. This should pop the case off. Note that force will need to be used. 1.    Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool into the connection point. This should pop the case off. Note that force will need to be used.
    • 1. Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool into the connection point. This should pop the case off. Note that force will need to be used.
  2. 2.    Remove the circuit board by unscrewing the 3 screws that hold it down. Note that specialised screwdrivers may need to be used.
    • 2. Remove the circuit board by unscrewing the 3 screws that hold it down. Note that specialised screwdrivers may need to be used.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. 3.    Remove battery by carefully detaching the connect wire that’s connected to the circuit board. Note that tweezers may need to be used to help pull the tab out. 3.    Remove battery by carefully detaching the connect wire that’s connected to the circuit board. Note that tweezers may need to be used to help pull the tab out.
    • 3. Remove battery by carefully detaching the connect wire that’s connected to the circuit board. Note that tweezers may need to be used to help pull the tab out.
  5. 4.    The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover. 4.    The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover. 4.    The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
    • 4. The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
  6. 5.    Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off. 5.    Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off. 5.    Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off.
    • 5. Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off.
  7. 6.    Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
    • 6. Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
Craig Lawrence
회원 가입일: 2010년 03월 11일
444 평판
안내서 1개 작성함
when i put the rear cover back on, the charging station doesn't line up correctly and the charging station sticks out a bit. any advice?
krnchang - 답글
is the batter swollen
Derek King - 답글
Yes, happened to a Zune 80 I have
Crazyblocks Technologies -
Thank you for this - took the fear factor out of changing battery on my much loved Nano!
jimbradshaw - 답글
It’s extremely hard to connect LCD and Button cables. I screwed it up while reconnecting the cables. IF, you want to disassemble this machine by fun, don’t ever try it.
Sizun Cho - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 13
30일 전: 82
전체 시간: 21,967
