주요 콘텐츠로 건너뛰기
iMac G5 17" Model A1058 Rear Panel Replacement
필요한 것
  1. iMac G5 17" Model A1058 Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Rear Panel Replacement: 2 단계, 이미지 1/3 iMac G5 17" Model A1058 Rear Panel Replacement: 2 단계, 이미지 2/3 iMac G5 17" Model A1058 Rear Panel Replacement: 2 단계, 이미지 3/3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Walter Galan
694,644 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 11,154
