학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Seat belt won't release
Whenever you pull your seat belt, it won't pull out all the way.
Seat belt is binding
It is possible that the belt is just binding on something, if this is the case try manually pushing the seat belt back through the shoulder harness.
Bad shoulder harness
If your seat belt is still getting stuck, you will have to replace the shoulder harness through which the belt passes through.
Alternator serpentine belt breaks
"The serpentine belt that runs your alternator breaks apart due to wear and age."
Belt Replacement
Replacement of the alternator serpentine belt starts with loosening the locking bolt on the side of the alternator bracket. After loosening the locking bolt, the tensioner bolt can be loosened and the replacement belt can be installed. After the new belt is installed, the two bolts can be retightened to the proper tension.
Headlights won't turn on
"Whatever you do, your front headlights won't turn on."
Blown Fuse
Check the fuse box underneath the steering column. Referencing the manual, locate the proper fuse and remove it from the fuse box. If the wire running through the fuse is not continuous, the fuse is broken and needs to be replaced.
Bad Relay
It is possible that the relay controlling the headlights has broken. If this is the case, locate the relay in the fuse box in the engine bay of the car. Referencing the users manual, find the correct relay and replace it.
Blown Bulb
A good indication that you have a blown a bulb is that only one headlight is out. Reach behind the headlight inside the engine bay and unscrew the bulb from the headlight. Inspect the bulb to see if the wire has broken and if so replace it.
Faulty Wire
If after checking all the other possible failures proves unfruitful, the most likely problem is a faulty wire. Although best left to a professional mechanic, you can bypass the bad wire. Snip the bad wire at the two ends and crimp a new wire to the two ends.
Oil needs to be changed
"After checking the oil dipstick, you discover you need to make an oil change."
Oil and oil filter replacement
Locate underneath the engine bay the oil tank. Place a drain pan underneath the tank and unscrew the drain plug to allow all the oil to drain out. Once all the oil has drained, screw the drain plug back into oil tank. Pour new oil into the top of the oil tank and unscrew and replace oil filter.
Door handle broke off
"When you go to pull the door handle, it rips right off."
Replace handle
Remove door panel and unscrew old door handle. Install new door handle and re install door panel to original position.
댓글 2개
Do you sell the Door Handle for 1992 Toyota Corolla?
Hailey Evans - 답글
the battery signal along with attention indicator shows up while the engine is working, Any help?
Solomon Endris - 답글
