학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Is your BolaButty X-GO C27-C failing to play audio? Use this troubleshooting guide to help diagnose why.
Speaker Not Connected to the Audio Source
The speaker is not producing any sound because it is not connected to an audio source.
Your Device Might be Muted
Check the volume settings on both the speaker and the audio source. Ensure neither is muted and that the volume is turned up to an audible level.
Audio Source Has a Problem
Try connecting the speaker to a different device. If it works, the issue likely lies with the original audio source. If it doesn’t, the speaker itself may be the problem.
Device Has Water Damage
If the speaker is making a distorted sound there may be hardware problems.
None of the Above Troubleshooting Steps Have Resolved the Issue?
If all else fails and the speaker still isn’t working, it may be time to replace it. Seek a professional diagnosis if you're unsure, but replacement might be the most efficient solution.
댓글 0개
