학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Juicer is on but won't work
Machine has been turned on but will not function properly
Disengaged safety locking arm
If you turn the machine on and nothing happens, one possible problem is that the safety locking arm isn’t engaged. If the locking arm isn’t in the correct place, the juicer won’t turn on. To engage the locking arm, make sure to snap it into the two grooves on either side of the juicer cover. Once it is securely fixed in that vertical position, you should be ready to go.
Juicer stalls
Motor stalls when juicing
Pulp build up
If the motor appears to be stalling when juicing or it won’t start right, it could be the cause of pulp buildup. If wet pulp is built up under the juicer cover, slow the juicing action by pushing the food pusher at a slower rate. Disassemble and clean the filter bowl, stainless steel filter basket, and juicer cover. Check for any food left in the feeding tube or by the blades, and clean thoroughly before use.
Excess strain
On a low speed, hard fruit and vegetables will cause excess strain on the motor and could cause it to stall. Please refer to the juicing guide (page 15) to find the correct speed for a specific fruit or vegetable. If the motor continues to stall or not work properly, unplug the juicer and wait 10-15 minutes before using it again.
Juicer extracting less juice
Less juice is being produced than normal
Filter basket is clogged
If the juicer is extracting less juice than it normally does, or the pulp is very wet, the filter basket might be clogged. Remove the filter basket and wash with soap and water. If the filter basket is still clogged, soak in a mixture of half bleach, half water for 20 minutes. Wash with soap and water before resuming juicing. If cleaning the filter isn't helping, you might need to replace the filter (especially if it is old).
Pulp build up
If the filter has been cleaned and the juicer is still not extracting as much juice as it previously had, then pulp build up might be the issue. Stop juicing and clean the juicer to ensure maximum juicing ability. This video cleaning tutorial is a helpful guide.
Juicer leaks
Juice is coming out of the machine
Extreme juicing speed
If juice is being extracted too rapidly, one of two things will happen. Juice will either leak between the rim and the cover, or juice will spray from the spout. If either of these occur, the juice is being extracted too rapidly. First attempt a lower juicing speed, and for extra measures, push the food down the feed chute at a slower rate.
Dirty Filter Basket
Another reason why the juicer is leaking could be that there is pulp or other contaminants in the filter basket. To stop the leak, remove the filter basket and clean it thoroughly before putting it back in.
Juicer won’t turn on
The machine won’t turn on, and doesn't seem to be functioning at all
Faulty wall outlet
If your juicer won’t turn on, first test that your wall outlet is not faulty. You can do this by attempting to power the juicer from a different wall outlet.
Blown out fuse
If your juicer is not turning on and is completely inoperable, you might have a blown fuse. First, turn the on/off switch to the "off" position. Next, unplug the juicer. Open the blender and remove the old fuse by unsoldering it from the circuit board. Solder the new fuse back into place and replace the cover.
The internal components of the JE98XL are very difficult to access, so if you are having trouble, refer to Breville support
If you need information and tips on soldering, refer to iFixit's Soldering Skills for some helpful guides.
댓글 17개
OK. So not the fuse. The E light won't turn off even after waiting 24 hours. LED lights motor doesn't make a sound. Do I replace safety switch
Yvette Gaston - 답글 공유
When I use my Juicer after a couple minutes every time I pull the plunger it stop adn lights starts to blink overload.. why is this happening
Traci S. McILwain - 답글 공유
Hi Traci! Did you receive any resolution? I’m going through the same at the moment. Any word will help!
Ivanna Marin - 답글 공유
Seems to be a lot more pulp or sediment in my juice, it use to be pure juice. Why is that?
trentwulf - 답글 공유
After discovering our juicer filter was significantly clogged, the best way I found to clean it was soaking it in recently boiled hot water and oxiclean for 15 minutes, then scrub. Magic!
scotney.young - 답글 공유
