학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Issues with the power button not moving or turning on computer
The laptop won’t turn on
Power button issue related to hardware
Try removing the panel and press on the main power button inside. If it works perfectly, then the issue is the external cover/panel. In this case, the panel will need to be replaced.
Power button issue related to software
Operating Systems have options on how the laptop responds when the power button is pressed.
Open “Control Panel”, “All Control Panel Items”, “Power Options”, and click on “Choose what the power buttons do”. Choose or customize your power plan.
Laptop frequently overheats causing the computer to shut down
Your computer gets hot to a concerning degree when in use
The average temperature your computer should have
The average temperature of your computer should be around 130 degrees Fahrenheit during heavy usage. Due to the construction of the air intake vents and the type of processor being used in the laptop, this temperature is normal. If you are outside in a sunny environment, however, the computer may formally overheat and shut off until the system has cooled down.
Checking BIOS settings
Open your BIOS settings to see if you have turned on the Intel Turbo Boost. If yes, then your Core Frequency will be maxing out all of your core processors all of the time. Since this is not always needed for every single task, this is an issue that can lead to overheating. Turn off this feature to alleviate the processing power going into each task.
Audio quality issues
The sound on my computer is muffled, quiet, fuzzy, or completely not working.
Wrong level in your audio settings
First, go to the sound menu on the toolbar at the bottom of the screen. Right click the sound icon to open the audio menu. Open the volume mixer to ensure that your computer is electronically registering that it is sending audio to the computer’s speakers.
Muffled audio
If your sound is muffled, it may because of debris being caught in the speaker grill. To clear away the debris, first, try blowing into the speaker grill. If this strategy does not work, you will have to remove the back panel and other components around the speaker grill to clear away blockage of the speaker screen.
Computer doesn’t connect to Wi-Fi
Your laptop does not want to connect to any WiFi networks
Wrong WiFi Settings on Laptop
First, make sure your WiFi is on by going to setting and selecting “Network & Internet”. There should be an indicator light on your laptop that shows the WiFi is on. Then, go to “Show available networks” and connect to the network you expect to see. If this does not work, you can also go to settings and make sure your airplane mode is off.
Delete all networks from your settings and reboot the laptop.
Run a wireless network report. The report is meant to give you information about what is causing the issue and it can redirect you to others who can help you.
Wireless router does not connect to device
If the laptop settings are not the issue, try moving about 3-9 feet away from the router.
Restart your wireless router. To do this you will need to follow these steps:
Unplug the router from its power source.
Wait around 30 seconds and replug the router to the power source.
Wait a few minutes until the router is completely on. You can tell when it is completely on by looking at the status lights.
Reconnect laptop to the corresponding WiFi network.
댓글 한 개
So like i changed the thermal paste, installed a new ssd, installed windows 10 pro i installed the 1511 version of Windows 10 pro everything went well for like 20 minutes but after another 10 mins the audio started to glitch like every 10 seconds, i wasnt sure why it was happening so i reinstalled windows but the problem still remained
I have no idea how to fix it, I would really appreciate it if someone could help me out
GamerBoy9000 - 답글
