학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Laptop is Overheating
The laptop is abnormally hot.
The laptop is being charged during use.
Extraneous use of the laptop during charging will cause the laptop to become increasingly hot due to the amount of processes. Try not using the laptop to see if it naturally cools. Otherwise try shutting it down until the charge is fulfilled. If this problem persists, consider replacing the cooling system.
Too many processes are being performed at one time.
If too many tabs are left open in browsers or too many programs are being run at once, the laptop may begin to overheat. Try closing unnecessary tabs or background programs through the task manager of the laptop to attempt to cool it.
Dust in fans.
Dust in the cooling system may cause the computer to overheat. Try using a compressed air duster to remove dust from the cooling system.
The laptop was left in a heated area.
Try moving the device to a cooler area to check if the heat is coming from an external source than the laptop. If this problem persists and it is determined that the heat is from the laptop itself, consider replacing the cooling system (See our Fan Replacement Guide).
The cooling system is broken.
See our Fan Replacement Guide to replace the cooling system.
Battery Dies Quickly
The battery dies abnormally fast.
If too many tabs are left open in browsers or too many programs are being run at once, the battery life will be significantly affected. Try closing unnecessary tabs or background programs through the task manager of the laptop to conserve battery.
Brightness is constantly on high settings.
Consistently maintaining a high brightness can cause the battery to die quicker than expected. Try dimming the screen if a high brightness level is not needed to see in the environment to conserve battery.
There is a high number of previous charges.
Over time the battery loses capability of holding the maximum amount of charge it originally could, known as the battery health. Since this diminishes according to how many times it has been charged, a laptop that has been charged consistently over a long time will have a worse battery life than a factory new product. Consider replacing the battery if this problem persists (See our Battery Replacement Guide).
The laptop has not been completely turned off recently.
Completely turning the laptop off ends the laptop’s background processes while sleep mode maintains many of the program’s functions, therefore using the battery of the laptop and depleting it.
The laptop has been left in extreme temperatures.
The laptop’s battery life will decrease if consistently left in extreme heat or cold. If this happens, the battery will hold significantly less charge and a battery replacement could be considered to fix the issue (See our Battery Replacement Guide).
The laptop has been consistently playing audio out of the speakers.
Using the speakers of the laptop can cause the laptop battery to drain quicker than usual. No harm will be done to the battery long-term, but the battery life while the audio is being played will cause the battery to drain.
The battery is faulty.
See our Battery Replacement Guide to replace the battery.
The Touch Pad Doesn’t Work
The touch pad is not responding when the device is turned on.
The touch pad may be disabled.
The touch pad for the HP Envy x360 contains a setting allowing manual disabling of the touch pad through double clicking the top left corner of the touch pad with your finger. To re-enable the touch pad, double click the top left corner of the touch pad with your finger.
There may be a software issue.
This may be a software error that could be fixed by performing a power reset on the laptop. Before you restart, turn the device off and unplug all external devices from the laptop. Then, remove the battery and power adapter. After they are removed, hold the power button for 10-15 seconds to drain any residual power and reinsert the battery and power adapter. Finally, turn the device back on.
The drivers may need to be updated.
Plug in an external mouse to navigate to hp.com/drivers. Use this site for instructions on how to install the latest drivers for the touch pad.
The touch pad is broken.
See our Touch Pad Replacement Guide to replace the touch pad.
The Screen is Black
The screen goes black even when the device is on.
This may be a software error that might be fixed by performing a power reset on your computer. Before you restart, turn the device off and unplug all external devices from the laptop then remove the battery and power adapter. Next, hold the power button for 10-15 seconds to drain any residual power. Insert the battery and power adapter and turn the power back on. If the problem persists you may need to perform a BIOS recovery which can be detailed on HP’s website.
The drivers need to be updated.
To update your drivers, connect your laptop with a HDMI to an external monitor. Press the F4 key to switch the display to the monitor. Use this to navigate to hp.com/drivers for instructions on how to download the latest graphic drivers for this laptop.
The screen is faulty.
See our Screen Replacement Guide to replace the screen.
The Touch Screen Doesn’t Work
The touchscreen does not work when the device is on.
The screen may be dirty.
A dirty screen may cause the touchscreen to not work properly. Make sure to clean the screen by applying screen cleaner to a rag and cleaning the screen with it.
The touch screen may be disabled.
The touchscreen feature may be disabled but can be enabled with these steps. First, press the Windows key and X. A menu will pop up and select “Device Manager.” Open the drop-down menu under “Human Interface Devices.” Select “HID-compliant touch screen” and select “Enable.”
댓글 0개
