학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Tablet Not Charging
When I plug in my charger, the battery doesn't charge.
Power Outage
Check to make sure there is not a power outage in your area and that the outlet your charger is connected to is functioning properly. Try plugging the charger into a different outlet.
Charger Not Plugged In Correctly
If the charger is not working, it might not be plugged in correctly. Try inserting the charger differently being sure not to force it, as that could damage the charger or tablet.
Charging Port is Blocked
The charging port might be blocked by dirt or other particles. Try cleaning the port out with a small, thin wire or brush.
Faulty Charger
If the charger is not working, it might be faulty. Try using a different functional micro-USB charger.
Faulty Charging Port
There might be an issue with the micro-USB charging port, which is soldered to the motherboard. Consider replacing the motherboard using this guide.
Tablet Not Powering On
When I try to turn on my tablet, the screen stays black.
Battery is Dead
If your tablet fails to turn on, the battery might be dead. Try plugging in the charger and waiting a few minutes.
Faulty Battery
If you've tried charging your tablet, but it still does not power on, the battery might be faulty. Consider replacing the battery using this guide.
Faulty Motherboard
Tablet Camera Not Working
When I try to take a photo, the picture is black.
Surroundings are Too Dark
The area in which you are trying to take a picture may be too dark for the camera sensor to pick anything up. Try moving to an area that has better lighting.
Camera is Covered
The camera may be blocked or obstructed. Check to make sure items like stickers or cases are not blocking the camera.
Software Issue
There may be an issue with the software of the tablet that is preventing the camera from functioning properly. Try turning the tablet off and on again. If restarting the device does not work, refer to this page about factory resetting the device.
Faulty Camera
There may be a hardware issue with the camera, consider replacing the camera by following this guide.
Tablet Screen Not Responding to Touch
When I touch the screen, nothing happens.
Fingers Covered
If your fingers are covered with a glove or residue, the screen may not respond to touch. Try removing any gloves or washing your hands making sure to dry them thoroughly.
Software Issue
There may be an issue with the software of the tablet that is preventing the screen from responding to touch. Try turning the tablet off and on again. If restarting the device does not work, refer to this page about factory resetting the device.
Screen is Damaged
If there are significant cracks or other damage to the screen, it may not respond to touch. Consider replacing your screen using this guide.
Tablet Not Playing Sound
When I play a song or video, no sound comes out of the speakers.
Muted Sound
If there is no sound coming from your tablet, the volume may be turned down. Check the sound buttons on the side of the device. Press the top volume button until desired volume is reached.
Speaker Covered
There might be something blocking the speaker. Try moving the device away from anything blocking the speakers. Also, look at the speakers to see if anything could be cleaned to improve sound.
Faulty Speaker
There might be something wrong with the speaker itself. If so, consider replacing your speakers using this guide.
댓글 3개
What about tablets turning on and the screen is still grey?
Scarlett Bleeder - 답글
No suound coming from tablet
Andrea Francois - 답글
No sound from
