학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Battery runs out of power
Every time you try to turn on the camera it won't turn on whatsoever.
Degrading Battery
If your camera is not turning on and it has something to do with the battery it may be time to get a new battery to replace your old one.
Blue or black screen is displayed
Every time the camera turns on the screen is not responding
Restart the camera
When you restart the camera, and the blue or black screen still shows up then you should change the image storage location to initial memory.
Inconsistent movement of the lens
The camera lens acts stiff or goes in and out of focus without making an effort.
Replace the lens
If the lens is stuck or not retracting, try gently pushing or pulling on the lens while turning the camera on and off. If the lens is dirty or has smudges, use a microfiber cloth to gently clean it. If the lens is scratched, it may need to be replaced
Restart Camera
If cleaning the camera does not change the movement of the camera, it would be a good idea to transfer pictures to a different device and restart the camera.
Remove battery
Turn off the camera remove the battery and wait for a few seconds, then reinsert the battery. Turn on the camera and check if the lens error has been resolved.
Jammed shutter button
The shutter button appears to be stuck / Jammed.
Cleaning the shutter button
some isopropyl alcohol (70-80%) and spray a small amount in there. Work it by pressing or wiggling the button. Once the button releases, you’ll want to use some more and keep using the shutter button for a bit to loosen it up.
Flash does not fire
While trying to take pictures the flash does not want to fire.
Charging the camera
The charging cable you need is a Micro USB Battery Charger. Locate the charging port on the bottom of the camera. Insert the Micro USB into the port, your camera should start charging unless the port or cable is damaged.
If you do not have the cable, this is an option to buy one Here (hyperlink needed)
The flash might not work because it is on low battery, it would be a good idea to make sure that it is fully charged before moving on.
Change the camera setting to see if it would work
Go to your settings on your camera and check your flashing settings.
댓글 0개
