학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Camera Will Not Turn On
You have tried numerous times to turn on camera and nothing happens.
Loose On/Off Button
Even though the camera is not turning on, you notice the on/off button is not loose and not responding.
If this is happening with your camera the on/off button will need to be replaced. I have completed a clear step by step guide to help you complete this replacement.
Faulty Battery/Memory Card Cover Lock
You have tried numerous times to close this cover lock and it's not sticking.
If you are having issues closing the battery/memory card cover lock you will have to replace the lock on the camera. I have completed a clear step by step guide to help you complete this replacement.
Faulty Lens Cover
The lens cover needs to be replaced. The camera lens is not protected from dust or getting scratched due to the lens cover not working correctly.
You will need to replace your lens cover if its unresponsive. I have completed a clear step by step guide to help you complete this replacement.
댓글 0개
