학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Picture has Black Spots on it
When I take a picture, there’s black spots or smudges on the image.
Dust/smudges on the lens
Most often, smudges or specks on an image are dust particles or other unwanted things resting on the camera lens. This can be commonly fixed by applying a gentle brush/lens cleaning fluid to the camera lens to remove dirt, dust, fingerprints, and other blemishes.
Dust/smudges on the sensor
If the spots persist after cleaning the lens, you may have dust/smudges on the camera’s sensor. By gently removing the lens of the camera, one can use a manual air blower or a specially made sensor brush/solvent to remove dust/smudges. For a guide on taking off a camera lens, please go here.
Damaged lens/sensor
For obvious reasons, damaged lens/sensors should be replaced whenever possible. For a guide on replacing damaged lenses and sensors, please go here.
Unresponsive Screen
The camera’s screen appears black or won’t respond no matter what I do.
Camera should be restarted
In most cases, turning the camera off and restarting it via holding the power button down will fix an unresponsive screen. If that fails, remove the battery and hold the power button for 15-30 seconds. Wait a few minutes before replacing the battery and restarting the camera.
Screen is damaged
If the screen fails to turn on entirely, this may be an issue with the screen’s hardware, and it may need to be repaired/replaced. You can see our guide to fixing/replacing an LCD screen here.
Camera is not charged
Ensure that the camera has enough charge to properly turn on by replacing the dead battery with one that has charge.
Camera is in power save mode
You can disable power save mode by turning on the camera and accessing the power save settings within the setup menu.
Camera won’t take a picture
My camera is on, but when I click shutter the button, it doesn’t take a picture.
'The memory card is not inserted properly'''
If the memory card is not secured, your camera will not be able to take pictures. Slide the release lever in the direction of the arrow and open the card/battery door. Push it securely all the way until you hear a “click” while being careful about the direction in which you insert it. To remove the card, push the card until it clicks, then pull the card out upright. Do not touch the connection terminals of the card. Close the card/battery door. Slide the release lever in the direction of the arrow.
Shutter is stuck
Face your camera towards you and try to take a photo. If your shutter doesn’t flicker, it’s likely jammed. Trying to fix a jammed shutter is tricky and doing it yourself could further damage your camera. We advise that you send it back to Panasonic to let the experts handle it.
Shutter button is stuck
If you can feel that the shutter button is sticking when you are trying to take a photo, that is likely the cause of this issue. You can try to clean the shutter button by holding it down with something like a pencil and blowing on it with a can of compressed air. It can be risky to apply any liquid on the button, so if you don’t have luck with the compressed air, your best option is to replace the shutter button.
Jammed or Stuck Lens
The lens is unable to extend, retract, or is stuck out-of-position; display shows the error message “System Error (Zoom).”
Zoom System is Not Receiving Power
When switching between the playback and shooting modes, you should hear the zoom motor running if everything is operating normally. If the zoom motor is not running, the lens will jam, and you may require a new zoom motor unit. We advise that you send the camera back to Panasonic to let the experts handle it.
Condensation on Lens
Check to see if there is any condensation or “fog” on the lens front. Prolonged presence of condensation can cause stains, fungus buildup, and camera malfunction such as a stuck lens. Carefully wipe the condensation/fog off with a soft cloth or let the camera sit in a temperature adjusted area.
Sand/Grit is Stuck in Between Lenses
If any particles are preventing the extension of the lens, blow compressed air in the gaps around the lens barrel and push them out of the camera.
Guide Pins Are Out of Place
It's possible that the guidance pins that keep the lens and lens barrel in place are offset, causing the lens to jam or leaving it stuck. Place the camera flat on its back on a table, lens facing upward. Hold down the shutter button while simultaneously holding down the power button. This will trigger the camera autofocus as the lens tries to extend, letting the guide pins of the camera lens’ barrel move back to their precise spots.
Camera Will Not Power On
When I press the power button nothing happens.
Dead Battery
If the camera battery is dead, the camera will not turn on. If the camera won’t turn on after charging, the battery may be malfunctioning or need replacement.
Faulty Charger or USB Cord
If the battery refuses to charge without there being any apparent issues with the camera itself, the charger may be broken. A damaged USB cord could also potentially be causing the problem. Replace the charger or the USB cord if you sense there is an issue with either.
Flash is not working
When I try to take a picture with the flash, the flash won’t fire
Finger is covering the flash
A very common problem that happens more than you would think is your finger covering the flash. This flash is located under the shutter button and is in the prime real estate where your hand falls. Be mindful of where your fingers fall.
In the wrong mode
The flash simply is not a feature in a couple of the modes that are on your camera. Ensure that your mode wheel is in one of the settings below where the flash is able to fire.
Broken Flash
Your flash could just be broken and will need replacement. To replace the flash follow the directions in this guide.
댓글 3개
How can I set the time on the camera?
leewvi - 답글
How can I set on the camera
leewvi - 답글
Is there another way to transfer pictures from the camera to another device other than using the Panasonic image app? The app isn't working. The wifi is able to connect to my iPhone but the app itself isn't recognizing the camera.
Samantha Calick - 답글
