학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Tablet will not turn on
Tablet will not come on when power button is pushed.
Hold down power button (sleep button) for 30 seconds. Plug in tablet for one hour then hold down power button again. If tablet still does not power on hold down the power and volume up button at the same time.
Tablet is not charging
Check the power cord to charger; test charger on another device . Look for flashing light on tablet to indicate that charge is powering tablet.
No display
Hold down power button (sleep button) on the Quantum view tablet for 30 seconds. Plug in tablet for one hour then hold down power button again. If tablet still does not power on hold down the power and volume up button at the same time.
New tablet is not turning on
Plug the tablet into the wall charger and let the battery charge overnight. Then turn on the tablet the next morning. Windows will automatically launch the setup routine. After making a few quick selections, You will find your self looking at a usable Windows 8.1 Start Screen. The entire process will take about 5 minutes.
After that initial startup/setup sequence, the tablet now fully boot to the Start Screen in about 10 seconds.
Device Information
A crystal-clear 10.1″ Touch Display
An Intel Baytrail-T (Quad-core) 1.5 GHz CPU
2GB of fast DDR3 RAM
32 GB Integrated Flash Storage
1 Mini-HDMI Port
1 USB port
Detachable Keyboard and Track pad integrated into an attractive Carrying Case
Wall charger
Micro-USB Cable
Front and rear facing cameras
Troubleshooting
http://ecx.images-amazon.com/images/I/61...
댓글 2개
Does the title on the troubleshooting page title match the name that appears on the white iFixit
label on the device? The title should match this label with the word "Troubleshooting" appearing after the device name.
YES
Does the page have at least five troubleshooting topics/problems? YES
Does each topic have thorough explanations of the causes, symptoms, and solutions for each problem?
4
Does the page link to all of the device's repair guides in applicable solutions?
YES
Is there correct grammar and punctuation throughout the page? YES ALL CORRECT
Are the headers and sub headers all formatted correctly? YES
Does each topic follow the correct order of: YES
Symptom
Cause
Solution?
pascual - 답글
I am trying to download an app called viewclix to converse with an elderly relative, however, when I click on the store, it says we are unable to connect, wait a few minutes try again. I have tried again and again, but it still won’t allow me to get a free app to my tablet
turner3038 - 답글
