학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Sony Cyber-shot DSC-T5 Troubleshooting
This Sony camera was released in September 2005, model number is DSC-T5. Use this wiki to help troubleshoot common problems with this product.
Battery will not charge
Charger is plugged into camera and wall and will not charge
Faulty Charger Or Wall Outlet
Try a new outlet to ensure that it is indeed the charger/camera that does not work. Make sure that the charger is properly plugged into the wall and charging port. Blow into the charging port to remove any dust. If all else fails you may need a new battery.
Dead Battery
The battery can be replaced by opening the panel on the right side of the camera. Take out the battery and put in a freshly charged, new battery.
Camera will not turn on
Camera is charged, but power button doesn't turn it on
Dead Battery
Broken Charger
Try charging the camera with a new charger in a new wall outlet to ensure it is the camera that is not functioning. Hold down the power button to turn it back on. Replace the battery if this fails.
Blurry image
Picture on screen is blurry
Dirty Lens
Make sure that the front cover is slid down. Clean the lens with Windex or similar cleaner and wipe.
Motion While Taking Picture
Even slight motion can cause the image to be blurry. Make sure the screen has stabilized before taking picture.
Camera turns off suddenly
While using the camera it shuts off without user doing
Extreme Temperatures
Bring the camera to a warmer location, and then plug it into the charger. This will power up the camera. Vice-versa if the camera turned off due to the heat.
Auto-turn Off Is Enabled
The camera has an auto-turn off function that may be enabled and is causing this issue. To disable go to Menu - Setting - Main Settings - Power Save - Desired mode. This will allow you to control when the camera turns on an off.
Charge indicator is incorrect
While charging, the light is not the correct color or no color is shown
Battery Pack Issue
Replace the battery pack with a new, freshly charged battery pack. Insert the new battery pack into the camera and turn on.
Cracked Light
Check to see if the light is cracked or damaged. If so plug battery into camera to see if the battery is charging, if not replace the charger.
댓글 1개
This is BULLSHIT, there is no real answer to any of the problems of this Sony Cyber Shot DSC T5. The charger is an exrernal part which has nothing to do with the inside of the camera, the battery can be charged with another charger. There should have been at least some facts about how to replace modules such as Back Light or just dismantling procedures.
KaivitiSingh - 답글 공유
