비공개
해당 위키는 검색 결과에 나타나지 않지만, 누구나 볼 수 있습니다!
T23036 Machinery Safety Instructions
Safety Instructions for Machinery
This is the page for general safety instructions for machinery. Information specifically related to Foot Shears can be found on this page.
Return the the Device page for the T23036 37" Foot Shear.
Owners Manual
Read and understand this owner's manual BEFORE using machine. Untrained users can be seriously hurt.
Wearing Proper Apparel
Do not wear clothing, apparel, or jewelry that can become entangled in moving parts. Always tie back or cover long hair. Wear non-slip footwear to avoid accidental slips which could cause a loss of workpiece control.
Eye Protection
Always wear ANSI-approved safety glasses or a face shield when operating or observing machinery. To reduce the risk of eye injury or blindness from flying particles. Everyday eyeglasses are not approved safety glasses.
Hearing Protection
Always wear hearing protection when operating or observing loud machinery. Extended exposure to this noise without hearing protection can cause permanent hearing loss.
Hazardous Dust
Dust created while using machinery may cause cancer, birth defects, or long-term respiratory damage. Be aware of dust hazards associated with each workpiece material, and always wear a NIOSH-approved respirator to reduce your risk.
Mental Alertness
Be mentally alert when running machinery. Never operate under the influence of drugs or alcohol, when tired, or when distracted.
Disconnecting Power Supply
Always disconnect machine from power supply before servicing, adjusting, or changing cutting tools (bits, blades, cutters, etc.). Make sure switch is in OFF position before reconnecting to avoid an unexpected or unintentional start.
Approved Operation
Untrained operators can be seriously hurt by machinery. Only allow trained or properly supervised people to use machine. When machine is not being used, disconnect power, remove switch keys, or lock-out machine to prevent unauthorized use--especially around children.
Intended Use
Only use the machine for its intended purpose and only use recommended accessories. Never stand on machine, modify it for an alternative use, or outfit it with non-approved accessories.
Children & Bystanders
Keep children and bystanders a safe distance away from work area. Stop using machine if children or bystanders become a distraction.
Stable Machine
Unexpected movement during operations greatly increases the risk of injury and loss of control. Verify machines are stable/secure and mobile bases (if used) are locked before starting.
Feed Direction
Unless otherwise noted, feed work against the rotation of blades or cutters. Feeding in the same direction of rotation may pull your hand into the cut.
Forcing Machinery
Do not force machine. It will do the job safer and bette at the rate for which it was designed.
Securing Workpiece
When required, use clamps or vises to secure a workpiece. A secured workpiece protects hands and frees both of them to operate the machine.
Guards & Covers
Guards and covers can protect you from accidental contact with moving parts or flying debris. Make sure they are properly installed, undamaged, and working correctly before using machine.
Unattended Operation
Never leave machine running while unattended. Turn machine OFF and ensure all moving parts completely stop before walking away.
Removing Tools
Never leave adjustment tools, chick keys, wrenches, etc. in or on machine--especially near moving parts. Verify removal before starting!
Maintenance & Inspection
A machine that is not properly maintained may operate unpredictably. Follow all maintenance instructions and lubrication schedules to keep machines in good working condition. Regularly inspect machine for loose bolts, alignment of critical parts, binding, or any other conditions that may affect safe operation. Always repair or replace damaged or mis-adjusted parts before operating machine.
Awkward Positions
Keep proper footing and balance at all times when operating machine. Do not overreach! Avoid awkward hand positions that make workpiece control difficult or increase the risk of accidental injury.
Dangerous Environments
Do not use machinery in wet locations, cluttered areas, around flammables, or in poorly-lit areas. Keep work area clean, dry, and well lighted to minimize risk of injury.
Experiencing Difficulties
If at any time you are experiencing difficulties performing the intended operation, stop using the machine! Contact our Technical Support Department at (570) XXX-XXXX.
댓글 0개
