학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Program Stops Responding
Program or Application freezes or slows down during use
High CPU Usage Has Caused the Application to Stop Responding
Press “Ctrl + Alt + Del” keys. Click “Task Manager” on the screen. Click the “Applications” tab. The program of concern will often display “not responding” beside the name. Select the program. Click “End Task”
Overheating
The unexpected shutdown of laptop after it has been on for quite a while, running difficult programs
Dust has built up in the fan
Clean the cooling fan with compressed air and/or a damp cloth. Not necessary to open the PC
Computer has been running for too long
Wait to allow the system to cool off
Cooling fan is broken
Please see replacement guide and follow instructions to replace fan
Driver Problems
Compatibility issues with different software. Frequently corrupted with malicious infections; Often characterized by the inability to access certain programs or the computer displaying error messages when attempting to utilize the associated resources
Compatibility Issues
Everyday scans keep your drivers up to date
Contact Toshiba Support
Computer Will Not Start
Computer screen stays dark and computer will not respond
Computer is Not Powered
Ensure the AC adaptor and power cord/cable are attached, and that the battery is properly installed and charged.
Computer Has Power But is Not Responding
Press and hold the power button for at least 10 seconds. Try to turn the computer off and then on.
Wall Outlet is Malfunctioning
Ensure that the wall outlet is working by plugging in another device, such as a lamp.
Verify that the computer is receiving power by looking at the AC power light. If the indicator is glowing, the computer is connected to a live external power source.
Broken Battery
Please see replacement guide and follow instructions to replace battery
Hard Disk Seems Slow
Accessing stored files seems slower than usual or operating system seems sluggish
Files Became Fragmented After Long Time Use
Run Disk Defragmenter. Click “Start”, “All Programs”, “Accessories”, “System Tools”, and then “Disk Defragmenter”. After it opens, click “Defragment disk”.
댓글 0개
