학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
The laptop will not power on
Your laptop fails to power on.
Faulty Power Adapter or Power Port
If the laptop is plugged in and the charging light in not illuminated, first verify that the adapter is not at fault by attempting to charge the laptop with a charger that has been verified to work. If the laptop now charges, your charger could be at fault.
- Buy a new adapter
If you are able to verify your charger is not at fault, then the laptop's charging port may be at fault.
- Replace the laptop's DC power jack
Dead Battery
If the laptop will not power on unless plugged in, the battery is likely at fault and will need to be replaced.
- Replace the battery with a new one.
The laptop won't boot
Your computer fails to load the Operating System and takes you to an error message.
Not Enough RAM
Your computer may run fine until you start doing work and notice performance is diminished, and tasks take longer to complete, or your computer occasionally freezes while doing certain tasks. This could be a sign of not enough RAM or faulty RAM. To fix this, replace the RAM you currently have in your computer.
- Buy new ram
Hard Disk corruption/error
Your laptop will inform you of a hard drive corruption or error, in such a case the drive may need to be repaired or replaced.
- Buy a new hard drive
- Repair current hard drive
The laptop "beeps"
If your laptop is not functioning properly and is issuing a series of beep codes, follow this link to find a possible solution.
- Research pattern to find the issue
There is no display
Your laptop's lights come on, there is no beeping, peripherals are able to connect to your laptop, and you are able to connect to a secondary screen.
Black screen
Ensure display has not been disabled accidentally by holding the windows key and then pressing the "P" key twice, this will take your laptop off projector mode. Also try simply restarting the device. If the black screen persists and there are no audible beeps, there may be a hardware issue and require a replacement screen.
- Buy a new screen, replace the old screen.
Device is overheating
Computer shuts down without notice while working.
Fan Stopped Working
Computer fans can be covered in dust resulting in inadequate airflow to cool the components within the computer. Fan can also break, requiring a replacement.
- Blow out vents, clear dust
- Replace the fan
Laptop will not recognize inputs
Device fails to detect when devices are plugged into ports
Will Not Read CD's or DVD's
If the optical drive fails to read and/or burn discs, it may be broken and need to be replaced.
- Replace defective Optical Drive
댓글 0개
