학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Fan Making Noise
There is a loud rattling noises when the device is powered on.
Dirty Fan
The fan may be dirty, this can be seen as lint or dust on the fan itself. Consider taking out the fan and cleaning it with compressed air and returning it to its proper housing.
Faulty Fan
The fan could also be damaged or not working properly. Check for rattling or no movement of the fan. Consult our guide on how to replace the fan.
Device Won't Power On
The device is not responsive and does not power on.
Faulty Charger
Plug in the adapter and make sure the light comes on. If there is no light indication, the adapter may be damaged, consider buying a new adapter. If the problem continues it may be an issue with the battery.
Faulty Battery
Plug in your device to a wall outlet using the adapter without the battery plugged in. If the device works properly with just the power from the adapter, the battery may be faulty. Using a voltmeter to check the voltage out of the battery terminals can also be done to check for proper battery function. Consult our guide on how to replace the battery.
Disconnected Hard Drive
If the battery is not damaged and you still experience problems with the device not powering on, the hard drive may be disconnected. Check the connection of the hard drive. If your hard drive is connected and your problem persists, you may need to install a new hard drive. Consult our guide.
Laptop Overheats
Device is noticeably hot to the touch and/or the performance of the laptop has slowed down.
Dirty Fan
The fan may be dirty, this can be seen as lint or dust on the fan itself. Consider taking out the fan and cleaning it with compressed air and then returning it to its proper housing.
Faulty Fan
The fan could also be damaged or not working properly. Consult our guide on how to replace the fan.
Not Enough Thermal Compound
Sometimes there is a lack of thermal compound on the CPU. This can cause poor heat regulation and can cause overheating. Consider applying more thermal compound between the CPU and the CPU fan.
Device Freezes
Device is unresponsive while powered on.
RAM Memory Issues
If the device has RAM issues, there may be error messages about lack of memory. Programs might not install correctly which may cause your device to freeze. Replace the RAM using our guide.
Faulty Motherboard
If your device still freezes, a rare problem could be a faulty motherboard. Consult our guide on how to replace it.
Device Cannot Connect to Wi-Fi
Device is unable to access internet.
Over-tasked Router
Router if left on for prolonged periods of time, can slow down due to a buildup of tasks. If you experience Wi-Fi issues, consider restarting your router first by unplugging the router from the power source and re-plugging it back in .
Device's Wi-Fi Module Cannot Connect to Wi-Fi
If you restart your router and still experience issues connecting to Wi-Fi, the Wi-Fi module in your device may be faulty. Consult our guide on how to fix it.
Messages About Memory
There are error messages about memory. The device may also be responding slowly.
Too Many Programs Running at Once
There may be too many programs running in the background. Open task manager and check to see the usage of your memory under the “Performance” tab. Then check the “Details” tab to see what programs are using the most memory.
More RAM Required
The device may not have enough RAM memory to keep up with your device’s needs. Consider adding more RAM memory to the device or replacing the current RAM memory with larger-sized memory sticks.
Faulty RAM
The device may have damaged or poorly performing RAM, consult our guide on how to replace it.
Hard Drive Issues
The device is crashing, error messages when moving files, lack of access to files, long time accessing files, or even loud noises coming from your hard drive can be signs of hard drive failure.
Poor Cable Connection
Check the device’s cables connected to the hard drive. Make sure they are properly plugged in and not loose.
Damaged Hard Drive
If the hard drive rattles or comes in contact with water or magnets, your hard drive may be damaged and need to be replaced.
댓글 0개
