학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Drone will not Connect to WiFi
Your drone will not connect to WiFi.
Mobile App not Installed to Device
Your drone will need to pair with the mobile app on your device to connect to WiFi. To download the app, you can either scan the Quick Response (QR) code found in the drone instruction manual, or on the box. If you cannot find the QR code, you can search for the app in your device’s app store using the search tag provided in the instruction manual.
Out of WiFi Control Range
Ensure you are within the 82 foot WiFi-control radius. If not, your drone is out of range. You must operate your drone within this range.
Signal Interference
The signal transmitting from your drone to your device may be experiencing interference from a nearby power source such as power lines or cell phone towers.
Scan the area of your flight zone for any such source and redirect your drone’s flight path away from the source.
Throttle Stick in Wrong Position
There are two ways to control your drone: from the controller or from the app on your device. When switching between the controller and device, pull the throttle stick on the controller to the lowest position before switching.
The Drone is not Paired with Controller
Ensure the indicator light on the controller is on. If it is on, there may be signal interference. Turn both the drone and the controller off, wait five seconds, then restart the drone and power on the controller. If the indicator light does not turn on, the controller battery needs to be replaced. For steps to do so, please visit the Udi Discovery U818A FPV Controller Battery Replacement.
Drone Camera is not Working
The camera fails to switch on or turn off.
Controller will not Turn Camera On
The camera is controlled through the mobile app on your device. The controller is not designed to operate the camera.
Camera is Poorly Connected or Unplugged
Crash landings or inflight bumps to the drone can sometimes cause the camera to unplug from the device. Check the camera’s connector wire, and reconnect if necessary.
Damaged Camera
If the camera has been damaged, it will need to be replaced. For steps to do so, please visit the Udi Discovery U818A FPV Camera Replacement.
Cannot View SD Card Images on Device
Pictures and video stored on your drone’s SD Card will not transfer to your device.
Signal Interference
SD Card is Unseated
Ensure the SD card is properly seated in the SD-card slot located on the camera. To do so, remove the SD card from the slot, make sure the metal side of the card is facing up, and then reinsert the card into the slot.
SD Card is not Formatted Correctly
If the SD card is seated properly and you still cannot view images, the card may need to be reformatted.
Camera has been Disconnected from Drone
Crash landings or inflight bumps to the drone can sometimes cause the camera to unplug. Check the camera’s connector wire and reconnect if necessary.
Damaged Camera
Drone does not Respond to Controller
Drone fails to respond when you use the remote controller.
Drone Battery is Low
Ensure the drone battery is securely connected to the drone. If it is, the battery may be low and will need to be replaced. For steps to do so, please visit the Udi Discovery U818A FPV Drone Battery Replacement.
Controller Batteries not Working
Ensure the controller batteries are free of dirt and debris and are seated correctly. If the batteries are dead, they need to be replaced. For steps to do so, please visit the Udi Discovery U818A FPV Controller Battery Replacement.
Drone will not Fly
Drone fails to take off.
Drone Needs to be Recalibrated
If the drone is not calibrated correctly, the propellers will not be able to operate at the correct angle needed to achieve liftoff. Refer to the device manual included with the packaging or follow the manual link provided on the device page for instructions.
Propeller Blades are Misaligned or Damaged
Ensure the propeller blades are in alignment as described in the device manual. If they have been damaged as the result of a crash, they will need to be replaced. For steps to do so, please visit the Udi Discovery U818A FPV Propeller Blade Replacement.
댓글 0개
