Student-Contributed Wiki
학생-기여 위키
해당 위키는 저희 교육 프로그램의 멋진 학생이 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Suzuki DR650 SE troubleshooting
'There are a few different ways to see/know if your engine oil needs to be changed.''
If the engine seems to be running louder/rougher than normal, the oil may need to be changed.
The oil usually lubes the clutch in a motorcycle. If the clutch is not working properly, it could be a sign you need new oil.
If you check the oil level and your dipstick shows a low level, you can bet your oil needs changing.
When you check the oil in your motorcycle, if the oil is dark and looks dirty, this is a definite sign that your oil needs to be changed as soon as possible.
More modern motorcycles have small dashboards with different warning lights. If a check engine light comes on, it could be an oil life indicator.
댓글 0개
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 186
