주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
209 질문 전체 보기
How to upgrade Mac Mini Server late 2012 Macintosh HD2 to 5TB?
The MMS late 2012 has a Server HD and a 1 TB Macintosh HD2 nearly full occupied by photos. I wonder if it's feasible to upgrade the 1TB Macintosh HD2 to a 5 TB hard drive and how?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
This question was migrated from http://meta.ifixit.com/Answers.
댓글 달기
답변 1개
선택된 답변
Sorry the Mini's use 2.5" drives so you're limited here on what available in this form factor. So far there are no traditional HD's that large that would fit.
So far the best you can do with traditional drives is 2 TB. I have a dual Spinpoint 2TB HD (4 TB total) Mini as my media server.
Now if you want to go bigger you'll need to go with SSD's using two Samsung 4 TB SSD drives which would get you 8 TB total!
But it will cost you big time!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I should also point out you can even go larger, hows 16 TB sound! If you can find enough loose change ;-}
Samsung Releases 16TB SSD That Only The Wealthy Can Buy. And this is whats coming: Samsung crams 32TB SSD into a 2.5-inch drive, aims for 100TB by 2020. Enjoy!
Thank you Dan. I'm happy to go for 2TB. How do I know which HDDs are compatible on MMS and macOS Sierra? At reasonable price and available with warranty?
Not sure I follow you here with your comment on MMS. You'll need a Mac compatible app to do that the drive has nothing to do with it.
As for macOS Sierra this Mac mini is on the supported listing so thats not an issue, and again the HD has nothing to do with it either as its just a standard SATA drive.
Click on the blue URL link I posted above it's the only drive that will physically fit as the height of the drive can't be any higher as there is not enough space for a bigger drive can some larger drives have.
댓글 달기
귀하의 답변을 추가하세요
Ivan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 1,261
