주요 콘텐츠로 건너뛰기
모델 A1347과 2.4 또는 2.66 GHz Core 2 Duo 프로세서.
76 질문 전체 보기
Damaged IR Sensor and Optical Drive Thermal Sensor connectors
I've done many, many repairs via iFixit's repair guides, and this is my first fatal mistake. In the process of changing the hard drive, I inadvertently pulled the logic board out too far and damaged the IR Sensor and the Optical Drive Thermal Sensor - the wires ripped right out of the connector. Note to self: buy a Logic Board Removal Tool next time.
Anyway, it wasn't clear to me from looking at the iFixit site if those parts (cables?) are available from iFixit. Is one of them part of the HD cable and the other part of the optical drive cable? If I need to sacrifice the optical drive, I'm fine with that, as I don't need it. The connectors in question are indicated in the attached picture.
I'm looking for whatever I need to buy to fix my mistake, and suggestions are appreciated - thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
In my case I broke the optical-drive-thermal-sensor socket clean off the logic board. I saved the socket. Is there any way to reattach the socket, or am I stuck having to buy a new logic board?
댓글 달기
답변 1개
선택된 답변
Here's what you'll need:
  • Thermal Sensor Kit, ODD/Ambient, w/tape 076-1370
  • Hard Drive Flex Cable, Top, w/sensor and tape 076-1360
Update (12/17/2016)
These are Apple P/N's for the Mac Mini, not the MacBook
Here's the parts from one source:
- Thermal Sensor Kit, ODD/Ambient, w/tape 076-1370
- Hard Drive Flex Cable, Top, w/sensor and tape 076-1360
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks, Dan.
Are those part numbers iFixit part numbers? Nothing is found when I search on the numbers. When I search on the part names, I get nothing for "Hard Drive Flex Cable", while "Thermal Sensor Kit" brings up 1 result for a MacBook 13" Mid 2009 part, but I still find such no part in the 68 listed for that MacBook.
댓글 달기
귀하의 답변을 추가하세요
mace 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 29
전체 시간: 2,548
