주요 콘텐츠로 건너뛰기
모델 A1347과 2.4 또는 2.66 GHz Core 2 Duo 프로세서.
76 질문 전체 보기
just tone and no boot after Mac mini mid 2010 16GB upgrade
After installing the upgrade the mac is just generating a tone every 4-5 second and does not boot. I saw on the guide page that at least 2 other users had the same problem. Anybody has an idea of what to do?
Thanks
Frederic
Update (09/25/2018)
I am running high sierra on that mac but, with only 2GB, it is struggling, hence the temptative upgrade…
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
댓글 달기
답변 2개
가장 유용한 답변
Do you still have the original RAM (in working order)? If so, try plugging the original RAM in and see if this behavior continues.
A beep every 5 seconds typically means bad, incorrect or no RAM.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
that is the first thing I tried. when I put back the original ram, it boots without problem. then I put back the 16GB and it went back to beeping. If it means no ram or bad ram could that be that I received bad RAM?
@freblewski Try @danj 's solution, then if that is a no-go you have probably received bad RAM. Comment below mentioning me if Dan's solution does not work.
댓글 달기
In order to run 16 GB you’ll need to be running OS-X Lion 10.7.5 or higher and make sure you’ve updated with the latest EFI firmware. The highest this system will run is macOS High Sierra 10.13.6
If you’ve not updated to El Capitan OS-X 10.11.x or newer you’ll either need to do that first or manually install the newer EFI firmware from here: About EFI and SMC firmware updates for Intel-based Mac computers
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
frederic reblewski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 594
