주요 콘텐츠로 건너뛰기
The M1 chip in the Mac mini is Apple's first System on a Chip for Mac, integrating GPU, CPU, RAM, and other components for improved performance and efficiency. The M1 in the Mac mini has an 8-core CPU with four high-efficiency cores and four high-performance cores along with an integrated GPU that has 8 cores.
14 질문 전체 보기
Device stalls at Choose Startup Disk - no options provided, spins
At power on, system chimes, logo briefly appears, then Choose Startup Disk. Select the system you want to use to start your computer has no options. Spinning circle, Restart button grayed out. Also does not recognize bluetooth mouse. Using plugged in keyboard. Tried commands and power up options with no difference. Will not enter any type of recovery. Keyboard worked initially to select language. Thought of installing new HD but see that is not an option. Am I left with a brick?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Sadly, there is no removable drive in this series the new M1/m2 based systems have soldered RAM and flash storage.
You could try booting up using another dive which had the required macOS on it using the Option (⌥) key
Reference: Mac startup key combinations
Otherwise it's time to visit an Apple Store to see what they can offer you for help. Sorry ;-{
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dennis R Tokarski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 30
전체 시간: 472
