주요 콘텐츠로 건너뛰기
LG G3 Battery Replacement
필요한 것
  1. LG G3 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 LG G3 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: 2 단계, 이미지 1/2 LG G3 Battery Replacement: 2 단계, 이미지 2/2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: 3 단계, 이미지 1/2 LG G3 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: 4 단계, 이미지 1/2 LG G3 Battery Replacement: 4 단계, 이미지 2/2
    • Lift the battery out of its recess and remove it.
결론
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 21명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
208,061 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
138 회원들
안내서 17,680개 작성하였습니다
댓글 한 개
Thank you very much!
ItayDigital - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 28
전체 시간: 17,624
