소개
MacBook Pro 13" Unibody Mid 2010 배터리를 교체하세요. 배터리가 부풀어 올랐다면, 적절한 예방 조치를 취하세요.
필요한 것
하단 케이스를 MacBook Pro 13" Unibody에 고정하는 다음 나사 열 개를 풀어주세요:
3mm 십자 나사 일곱 개
13.5mm 십자 나사 세 개.
상단 케이스에서 배터리를 들어 올려 분리하세요.
100%까지 충전한 다음 최소 2시간 이상 계속 충전하세요. 그런 다음 플러그를 뽑고 정상적으로 사용하여 배터리를 방전하세요. 배터리 부족 경고가 표시되면 작업 내용을 저장하고 배터리 부족으로 인해 노트북이 절전 모드로 전환될 때까지 노트북을 계속 켜두세요. 5시간 이상 기다린 다음 노트북을 중단 없이 100%까지 충전하세요.
새 배터리를 설치한 후 비정상적인 작동이나 문제가 발견되면 MacBook의 SMC를 재설정해야 할 수 있습니다.
기기를 재조립하려면 이 지침을 역순으로 따르세요.
다른 684명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 26개
You guys are awesome! My granddaughter spilled a whole coke on the Mac and it went fizz! After some weeks I took it to the Apple store where it was declared it dead. They offered me a refurbished machine for $800, but insteaed I came home, took the disk out and hooked it via a USB carrier to another Mac which proved that the disk had not been harmed. I put it back in the machine and booted up at which point it became obvious that the battery was dead. One pass at Google turned up IFixIt where I found the battery and the correct, goofy tri-point screwdriver. The battery arrived a bit ago and the Mac is up and running as if nothing happened . . . a tidy savings of $650!
Thanks so much1
This was a total life saver! A few weeks ago my house was hit by lightning and even though my computer wasn't plugged in (thank God!) my charger was completely fried. I ordered a new charger but my computer still wasn't working- Apple said my computer was done for. A friend said it was probably my battery and told me about ifixit.com. I was able to buy a new battery and change it myself (it was so easy!!!). Saved me from spending a bunch of $$ at the Apple store. I move out of the Country in a few weeks and didn't know what I was going to do without a computer. Thanks ifixit!!!
When I followed this exactly, I booted up my MacBook to see that my battery had an x through it with the no battery availible popping up when I scrolled over it. I (stupidly) left the computer on while I browsed for a solution. The whole time my charger showed a green light. Suddenly the computer turned off and hasn't been able to be turned back on since despite switching to another battery and another charger. The charger still shows a green light, which means the battery is either fully charged or installed incorrectly. I don't understand how it can be installed incorrectly when the only part to put it into the computer is the plug in. Please someone help me, I have no idea how to fix it and have made multiple forums on here asking for help, to no avail.
Jack Roche - 답글
I think you are SOL. I had same problem a few days ago. I have attempted everything I could find from online resources. Bottom Line: ship it to an Apple authorized repair shop or an Apple Store. Battery replacement Cost is now only $130, which isn't much more than iFixIt cost.
gkofga -
Your connector or socket may have broken. Open the Mac and check if you missed something.
