주요 콘텐츠로 건너뛰기
1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement
필요한 것
  1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: 1 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: 1 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: 1 단계, 이미지 3/3
    • Here is a view of the power steering pump. It is located on the front left side in the engine compartment. Visible fresh oil stains on the fan shroud and other parts.
    • Most sludge was found at the pressure line connection
    • The leak is on top of the flare nut where the pipe enters the pump.
  2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 2 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 2 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 2 단계, 이미지 3/3
    • To remove the hoses from the power steering pump, the air cleaner housing has to be removed. Remove the four clips on the air filter cover
    • Remove the air filter
    • Loosen the clamps from the air intake duct to remove the air cleaner cover from the engine.
  3. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 3 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 3 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 3 단계, 이미지 3/3
    • Here is the complete housing. There are three 13mm hex head mounting bolts for the air cleaner housing. One on the front left
    • one on the rear left
    • and the last one is difficult to find on the front right.
  4. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 4 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 4 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 4 단계, 이미지 3/3
    • All three bolts have lock nuts that can be accessed from the driver side front wheel well
    • Use a socket wrench or similar tool to loosen the bolts, then remove the nuts in the wheel well.
    • All three bolts and nuts are identical
  5. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 5 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 5 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 5 단계, 이미지 3/3
    • With the three bolts remove the air filter housing can simply removed. This gives full access to the power steering gear and hoses.
    • New line.
    • Use a 16mm x 18mm flare nut wrench. It will be safer than an open end wrench since it provides a better grip. This will prevent any damage to the flare nut on the hose.
    • Disconnect the hose on the power steering pump by loosing the flare nut in a counter clockwise rotation
  6. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 6 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 6 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 6 단계, 이미지 3/3
    • Disconnect the hose on the power steering gear by loosing the flare nut in a counter clockwise rotation
    • Once both ends are disconnected, remove the hose from the vehicle.
    • New line.
    • Install the supplied O-rings on either side of the new hose.
  7. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 7 단계, 이미지 1/1
    • Install new power steering pressure hose.
결론
다른 16명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,402 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 544개 작성하였습니다
댓글 9개
This was so helpful! I have this exact issue with my power steering and this guide is going to make the job very easy! Thanks for posting this it really helped a lot!
Hadley Hofreiter - 답글
Doing this job today thanks for making this! I didn't know I would need a flare nut wrench and luckily found one pretty cheap
Albert Einstein - 답글
After topping up the steering fluid, the system can be bled again by turning the wheels from left lock to right lock a few times. Much easier when both wheels are off the ground.
Andries Holtzhausen - 답글
Does the fluid not need to be drained out before removing the line?
Dave - 답글
@dave7777 nope. Place a rag under the hose before you take it off so it does not leave to much of a mess. Check the fluid after.
oldturkey03 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 40
30일 전: 161
전체 시간: 42,808
